i have a selection of eztrak parts and i have managed to 'sling' a machine together! i have gotten to a point where i am going crazy,over something that i hope is simple. the mc loads from the flash disk and counts down np,to 13 normaly,then the normal screen comes up and says emergency stop activated. i can run the spindle manually and i can test the estop and it stops the spindle ok.i can press in the axis run contactor and the 'x' motor is ok.i am unable to test the 'y' as i think that switches the big relay once homed(?) on the bmdc card i have a flashing green light and 1 red at the top(albeit its dim).both of the servo cards have green lights so i dont think a problem there. all i can think,is that the axis ref switches (not connected yet!) could be the problem??? the diagram is pretty vague as to how they are wired but i think both normally open is correct. i am loaded with version 3.17 as it was the only disk i could find here and it wrote itself to the flash card no problem. i have had 'spindle fault' alarm a few times,and the manual just says reset the MOL-1.....but the spindle runs and i can trip it pushing the trip to test the overload. could i still have a bmdc card fault?....or even is there a way to 'frig' this damn alarm out before i lose whats left of my hair!! ![]() any advice is welcome....as long as it refers to the machine ![]() regards ROB Last edited by BANKROBBER; 05-11-2010 at 12:36 AM. Reason: spelling!! |
....is in estop as it is looking for the door guards.however,this machine has no socket fitted to the cabinet for that.so what i need to know is; where does the original guard port plug in,so i can link it out(possibly fitting guards at a later date).is it connected to the axaux card or into the 'pc' direct? i think i have the wrong wiring diagram as it does not show the door guards in it. i have version 3.17 installed,i tried 3.07 but it wont work with the key switch fitted. apart from that,all the spindle/motors/scales etc are all tested ok.just this 1 problem then i will have a running machine! ROB |
| Part of the problem is that the configuration and software for a UK machine is different than one here in the US. Makes it difficult to give advice. George
....this is my biggest problem! have been talking to a hardinge engineer today and he is faxing me some various diagrams for the uk spec mc's he cant understand why i have 3position key switch and no interlock socket on mc.although it should have.....its a poss hybrid version,....pre bridgeport conversion to table guards etc.still....he seemed somewhat hopefull! albeit,i now have a EZ-Frankenstein!! ![]() ROB |
| estop | eloid | General Electronics Discussion | 8 | 02-15-2009 08:23 PM |
| estop diagram | markus_detroy | DIY-CNC Router Table Machines | 6 | 05-14-2008 11:00 AM |
| random estop | erase42 | DeskCNC Controller Board | 21 | 02-02-2007 05:28 PM |
| Estop | HuFlungDung | CamSoft Products | 5 | 03-06-2004 01:24 PM |
