Hello, i have a bridgeport machine that had a hdd failure and lost everything, I replaced with a new solid state drive and have had no luck with getting machine running right. If any one knows about this machine i could use some advice. thank you |
| Assuning you have a DX control and NOT a Heidenhain control: The software for the 760-16 is different from the software for the 760-22. Yours uses a air cylinder to move the tool carousel in and out. The 22 uses a motor. Check to make sure I am correct about this. After that, you have to set the orient position, the tool change height, backlash and the spindle speed and encoder parameters. This may be in the maintenance manual and I may have a start up sheet explaining some of this. After all, this goes back 20 years. I do not know when I will be in the office next to check. George
| Fanuc 0iMC param. problem. | GPena | Fanuc | 2 | 08-12-2009 10:05 AM |
| G112 NEED HELP TURNING ON PARAM MIYANO OT | INXS | G-Code Programing | 1 | 10-30-2008 07:53 AM |
| G112 NEED HELP TURNING ON PARAM | INXS | General CNC (Mill and Lathe) Control Software (NC) | 0 | 10-28-2008 02:48 PM |
| Fanuc param 923 problem ?? | trotsky | Fanuc | 3 | 06-22-2007 09:36 AM |
| Fanuc motor # for param 8420 OMC | OC_ | Fanuc | 0 | 02-20-2007 04:55 PM |
