I have an XYZ1500 (looks like a bridgeport)it weighs a max of 1400kgs. Whoever installed it never thought that you might need access to the computer at the back that controls the CNC and to it's almost flush to the wall. WHt's the procedure for moving these things please? never done it before. I only need to move it a couple of feet. Thanks!
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
| Johnson bar to pry it up followed by pipe to roll it on. Make sure you're not on any kind of slope! http://en.wikipedia.org/wiki/Johnson_bar_(tool) Cheers, BW
__________________ Try G-Wizard Machinist's Calculator for free: http://www.cnccookbook.com/CCGWizard.html |
| I have moved my BP clone half-way across the shop several times using nothing more than a crow-bar. Just slip it underneath, and slide one end a few inches, then do the same to the other end. You can move it 6 feet by yourself in a matter of minutes. Regards, Ray L. |
| Thanks guys! I'll give it a go... I have visions of of my hands slipping on the crowbar and it springing up into my nether regions
| Hi ImanCarrot If you have trouble with the crowbar, you can put a block of wood from under the knee, wind the knee down,(this will lift the front of the base up just enough to put the rollers in) Put 2 1/2" pipes or solid bar under the base, lower the knee, & roll it forward To take the rollers out, just reverse the above, if you have trouble getting the the first roller out,because it has moved back to far, you put a piece of wood under the back of the mill, wind the knee down, move the rollers forward, lower it back down, take the wood out of the back, & then lift the front again & take the rollers out, lower it back down & you are done Move the table to the front so you have the weight over the front before you jack it up This works great & have done it many times, & only jack it up enough to get the rollers in
__________________ Mactec54 |
| mactec54, that is a brilliant idea! one of them where you slap your own forehead and think "doh! why didn't I think of that!" Nice one! I tried the crowbar then a longer one and then a six foot pry bar with two metal wheels on it... couldn't move it more that an inch- just too heavy. So it's the knee trick. awesome man! thanks!
| Hi ImanCarrot Just take your time & you will get it done, I have posted ideas like this before, when you work by yourself, you have to figure ways to do things without to much sweat, Just follow what is in the post
#11
http://www.monumentalelevatorsupply....johnsonbar.jpg If yes, then that'd be a Johnson bar. |
#12
| As an aside... you know the spanner that everyone leaves on top of their mill to work the drawbar? Remove this prior to setting the machine down... it falls on your head lol *ouch*
| we need a programing manual for brigeport torq-cut 30 | saltfisherman | Bridgeport and Hardinge Mills | 6 | 02-03-2011 08:54 PM |
| Bridgeport lookalike power cut- how to reboot? | ImanCarrot | Bridgeport and Hardinge Mills | 0 | 04-23-2010 05:26 AM |
| Brigeport Interact 720 parts manual. | M.G.Machinist | Bridgeport and Hardinge Mills | 11 | 04-26-2007 12:43 PM |
| parremeters for tnc2500 on brigeport interact 1mk 2 | greg b | Bridgeport and Hardinge Mills | 6 | 11-28-2006 04:56 AM |
| X3 vs Zay lookalike | gto7419 | Benchtop Machines | 15 | 03-26-2006 12:27 AM |
