Old 04-29-2010, 04:11 AM
TarHeelTom is on a distinguished road
Which driver for Bridgeport Series 1 CNC
Am just starting to yank the guts out of a Bridgeport Series 1 CNC machine. Still got the BOSS 5.x stuff in it.
Intend to keep the stock steppers on it for now, maybe forever. What stepper drivers do you guys like for this application?
Second question. Maybe this is too ambitious, but I'd like to keep the original control panel, which is mounted on the side cabinet. This will mean trying to bring all the button etc functions into the computer, and generating outputs to drive all the led and number segments, etc, on the control panel. Has anyone done this before? Any guidance in this direction?
Tom
Old 05-03-2010, 04:55 PM
polaraligned is on a distinguished road
Gecko's will drive the original steppers. They are potential problems though. I would swap out new steppers which are relatively cheap. Get rid of the original control pendant...The first one here is mine mounted on the original series 1 arm that you can see at the left. I mounted everything in a steel cabinet from Automation Direct.
http://www.thewarfields.com/cnccookbook/MTCNCPanels.htm
Old 05-04-2010, 10:35 AM
BOSS 5.x computer bits and pieces
Just started removing all of the computer bits and pieces from a Series 1 CNC machine... It all appeared to be working when I bought the machine, but my shop only has single phase, so it's all got to go.
Does anyone need any of these bits and pieces? It's all coming out, and will be priced right. If you have a need for any thing from the computer case, let me know soon.
Tom
Bridgeport CNC Series 1 vs Series 2 jshank Bridgeport and Hardinge Mills 27 05-26-2012 08:51 AM
Need Help!- ormec f series servo driver murado Controller & Computer Solutions 0 03-28-2010 08:24 AM
Need Help!- About S Series Driver GFZ-65004,65005 cevyil Fanuc 0 04-28-2009 12:00 PM
Series 2 cnc 2 hp motor on a series 1 bridgeport? CATCH22 Bridgeport and Hardinge Mills 1 11-08-2008 08:18 AM
SLA series driver vulcom1 Stepper Motors and Drives 0 07-07-2007 11:27 PM
