Old 04-28-2010, 07:08 AM
hmc710 is on a distinguished road
BP axis stutter
We are running a BP series II Interact II w/TNC 145 control. After the machine has been running the x axis starts to stutter and jerk. I would stop and remove the way covers and manually lube the ways and run the table back and forth and it would seem to help. Yesterday it happened and got worse. As I moved the x back and forth the table sat there and shook like the x was trying to overposition its self back and forth. Could this be a tach or encoder issue? I haven't changed any MP since we had to re-enter them all when we got the machine.
Thanks,
Old 04-28-2010, 08:24 AM
Moderator
machintek is on a distinguished road
Usually a oscillation is a problem with the tach feedback circuit. First swap motors. If the problem follows the motor, it is the tach in the motor. I know when the tach is getting dirty by putting the machine in a slow feedrate. It should be smooth. Usually I have this problem on machines other than Interacts but with DC motors, And it usually is the cable.
George
Old 04-28-2010, 02:59 PM
Thanks George, that makes logical sense. I will check the cable connection and then see if the manual has any info on checking the tach.
Need Help!- threading stutter theatrewizard Haas Lathes 2 05-26-2009 07:08 AM
Machine has a stutter. donl517 Fadal 21 01-27-2009 04:43 AM
Motor stutter help! Cartierusm DIY-CNC Router Table Machines 1 10-13-2007 02:08 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
