Old 04-26-2010, 01:13 PM
79TigerPilot is on a distinguished road
Feed question
Just started milling on my restored & CNC'd 66' J headBP. I am cutting some 1018 steel with a 1/2" 2fl carbide end mill. I think I have the speed and feed dialed in for slot cutting, what I don't know is how one figures the plunge feed rate. What % of the horizontal feed rate does one use when doing a straight plunge cut? How aobut for a ramp?
Thanks,
Craig
Old 04-26-2010, 03:32 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
G-Wizard takes the horizontal feed rate and divides by number of flutes to get to a plunge rate. The more flutes, the less chip clearance you have, so you have to take it easy.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Old 04-29-2010, 08:07 PM
TarHeelTom is on a distinguished road
Don't know the answer, but your machine sure looks good.
Tom
Newbie- Question bout feed rates MynamesKenny19 General Metal Working Machines 2 03-22-2010 09:46 AM
Speed/feed question for HSM jmcglynn Haas Mills 11 08-05-2008 05:46 PM
Z feed question keen Tormach PCNC 11 09-28-2007 11:58 PM
Feed rate question studysession General Metal Working Machines 6 10-30-2004 01:00 PM
Another feed rate, cut depth question nervis1 General Metal Working Machines 8 02-09-2004 11:56 PM
