Old 04-17-2010, 12:44 AM
mark562 is on a distinguished road
BP Explorer Spindle Overload Alarm
Hello
Can anyone help? got a spindle overload alarm on my DX-32 and cannot clear it. I have shearched for the obvious blown fues or burnt wires, Is there a thermal protection reset that I am missing or did we burn out a motor or worse yet a board? Also my Interact 1 Mk2 w/TNC151 the spindle stopped mid cut and gave an E-STOP alarm. After complete shutdown and restart I cannot get past the E-STOP. any suggestion short of retrofit? Being new to this forum, these may be the same old questions but I had 2 machines fail in the same day.
Thank You
Mark562
Old 04-17-2010, 08:05 AM
gus gus is offline
gus is on a distinguished road
re
Dunno on the explorer, but on the interact, just follow the emo string.
limit switches, oil level, etc
get a manual, follow the flow chart, no real mystery
2 machines in one day, perhaps it aint the machines
Old 04-17-2010, 09:39 AM
Moderator
machintek is on a distinguished road
There are 2 large contactors that turn the spindle motor on for forward and reverse, then the 3 phases go through a overload. This overload has a reset button. Try that.
If the spindle air brake cylinder does not release, it will trip. or if you are tapping and do more than 6 spindle reversals a minute, it will trip.
George
Old 04-17-2010, 09:40 AM
Moderator
Are you by chance on a phase converter?
You may have lost a phase in the shop.
George
Old 04-17-2010, 07:08 PM
Thanks for the tip on the contactor reset button the explorer is back up and running. As for The interact, I have borrowed a frends maintenance manual and will try the flow chart monday. Hope it's as easy as the explorer.
Mark
Old 04-18-2010, 11:59 AM
Moderator
Interact 1 Mk2 has a spindle drive. Probably a KTK. That may be a large can of worms.
George
400 Servo Alarm (overload) on OM darrylh Fanuc 9 10-27-2011 08:42 PM
Need Help!- Bridgeport Explorer Spindle Taper? minton Bridgeport and Hardinge Mills 0 09-23-2009 11:28 PM
Explorer Spindle Enable johnhb Bridgeport and Hardinge Mills 2 10-30-2008 12:28 PM
Spindle starts in windows explorer cut2spec Benchtop Machines 4 02-26-2007 06:49 PM
Fanuc 3M servo alarm overload signal max_c Fanuc 11 04-10-2006 04:41 AM
