Old 04-16-2010, 11:43 PM
rlmomc is on a distinguished road
BP EZ Trak DX
Last year you were a huge help. Now I need you all again.
I have a EZ Trak DX with a 486 SX processor.
I had the machine shut down for 3 months. (No work)
It was working fine.
I went to turn it on the other day and I got a "No Signal"
on my monitor.
I can't tell if the hard drive is spinning.
The lights on the boards all come on.
Power to the spindle is fine.
I don't know where to start.
Any Ideas would be greatly appreciated.
Thank you
Rich
Old 04-17-2010, 09:45 AM
Moderator
machintek is on a distinguished road
Turn the machine On and watch the floppy drive. It should turn on for a few seconds and shut off during boot up.
If it does, the mother board may be working correctly.
Next, I would pull out the video board and clean the edge connector with a soft eraser. Put it back in and try it.
Get a old color monitor SVGA from a thrift store or borrow one. Plug it into the video board and see if that helps.
George
Old 04-17-2010, 10:51 AM
EZ Trak
George,
Thank you.
I'll try that. I did pull it and forgot all about cleaning the contacts.
A little more FYI:
In the last year I replaced the old CRT with an LCD monitor which was
working fine (and beautifully I might add).
I hope the simple solution will be it.
Rich
Old 04-18-2010, 12:48 AM
EZ Trak
Well I took a trip to the shop.
Switched it on and looked for a light on the floppy.
No light.
I checked for power on both the Hard Drive and Floppy drive
and there was power at the connector.
I took out all 3 boards and cleaned the contacts.
The long board (furthest left) lights up with 2 red led's.
I didn't have a chance to hook up the LCD monitor directly. Try that Monday.
Suggestions? Opinions?
Just odd how it was fine 3 months ago and I flip it on and "no signal"
Would a no power condition for 3 months affect anything?
Thanks in advance
Old 04-18-2010, 11:54 AM
Moderator
How old is your logic power supply? See if the fan is turning on it. Check power in and the fuse that protects it.
I will guess ther are no lights on the logic boards. The lights you saw were on the drives.
George
Old 04-19-2010, 08:52 PM
EZ Trak
Logic Power Supply is original to the machine.
I did notice the Power Supply fan was not running very well. I thought maybe it was time to replace it. When I checked Sunday is was not running at all.
However I did check the leads to the Hard drive and Floppy and they do have power. (also a third power supply under also had power to it)
As far as I remember there are 3 sets of lights. 1 each for each drive card.
Then another for a card connected to the mother board.
(as you probably know there are 3 cards connected to the MB.
I know the far right is the video card, the middle leads to an RS-232 connector
on the side of the machine, and the 3rd, the longest of the 3 has 2 led lights.
Those are the ones that light up.
I know that the top of the Power supply is has a plug where it gets power from the transformer. If I disconnect this plug the lights go out on that long board.
Hope I gave you enough info.
Oh I have checked all the fuses that are visible.
total of 11 I believe, including for the machine itself.
3 lower right, and 3 upper left of the cabinet. 1 one each drive card.
Are there others?
Thanks so much
Rich
Old 04-20-2010, 08:32 AM
Moderator
It still sounds like the mother board is not running. The red to black on the plug is the 5 VDC. It has to be 5 VDC with a digital meter. If it is not, the mother board will not think correctly.
I used to carry a small PC speaker that I could plug into a J connector on the mother board. The beeps indicated some faults with the mother board. A lack of beeps confirmed a dead mother board.
You could try a power supply (I recommend a new one anyway). But if you need a mother board, it is a trip to a thrift store or dumpster diving (or EMI for about $700.00).
George
Old 04-20-2010, 11:43 AM
EZ Trak
I will also take a speaker with me. (I'll borrow it off an old computer I have)
this will tell me if it's the MB as you said and should tell me if that's the problem or not. If beeps indicate problems, and no beeps indicate a dead MB,what would indicate a good motherboard?
I will check the leads for 5v today.
I assume if I get the correct voltage then the Power supply is ok?
I found the schematic to it and will make sure I checked every fuse as well.
As for dumpster diving and thrift stores....recommend any good dumpsters &
thrift stores?
Thank again
Rich
EZ Trak DX Flying A Bridgeport and Hardinge Mills 6 01-08-2010 05:15 PM
EZ-Trak - b3t.exe DSlezak Bridgeport and Hardinge Mills 6 10-28-2009 12:37 PM
EZ-TRAK DX help please doctordemo Bridgeport and Hardinge Mills 10 11-22-2007 10:07 PM
ez-trak rsbbmw Bridgeport and Hardinge Mills 6 06-07-2007 02:08 AM
Need help with EZ-Trak SX II Steve@Reliance Bridgeport and Hardinge Mills 13 09-26-2006 10:51 AM
