Old 04-14-2010, 12:20 PM
charliemisa is on a distinguished road
Bridgeport Torq Cut 30
drives will not start up.getting no errors but on the maintenance page it says "drive command failed at bmdc".After several attempts you can get the drives to start up.We can run some parts for a hour or so and then get a BMDC COMMUNICATION ERROR.
Old 04-15-2010, 08:44 AM
now after powering down it goes to the machine check blue screen and goes no further.done BMDC (B3T.EXE) board check it says BMDC NOT RUNNING....LOADING BMDC.....WAITING FOR BMDC...BMDC3 TIMEOUT
Old 04-16-2010, 10:03 AM
Moderator
machintek is on a distinguished road
Either software is corrupted (or CMOS not set correctly) or BMDC is not communicating.
Remove BMDC carefully and clean edge connector with a soft eraser and reinsert.
If still not working try looking for B3T.EXE in DOS on your mass storage device. Run that and see what it tells you.
George
Old 04-23-2010, 06:11 AM
Ok....got it going and it ran for a whole week and got the BMDC communication error again while it was sitting idle whem operator was on break.Pulled BMDC board and reseated and its running again.All board contacts have been cleaned prior to this.Any ideas?....HELP!!!!!!!!!
Charlie
Bridgeport Torq-Cut TC 3G?? Kristjan Bridgeport and Hardinge Mills 14 03-31-2011 01:04 PM
Bridgeport torq cut-22 problems!! baystard Bridgeport and Hardinge Mills 15 01-17-2008 01:22 PM
bridgeport torq cut 30 shot pin porkchop21 Bridgeport and Hardinge Mills 2 08-08-2007 11:21 AM
Bridgeport Torq-Cut 2G-????? bherr Bridgeport and Hardinge Mills 17 10-21-2006 12:56 AM
Bridgeport Torq Cut 22: What lubricants? Where? How? vettespeed Bridgeport and Hardinge Mills 5 06-24-2006 01:38 PM
