Old 04-09-2010, 07:58 AM
imac is on a distinguished road
Exclamation bridgeport xr 760
So I was breaking down my set-up on my mill yesterday after noon and after doing a tool change this part feel out of my machine and as anyone with a Hardinge or Bridgeport will tell you since changes in the company free help has been limited. So I want to post the picture here and see if anyone can help me identify b4 I am forced to call the service guy. Any response is greatly appreciated. Thanks, the-mac.
Old 04-09-2010, 09:46 AM
Exclamation
BUMP^
Old 04-16-2010, 06:50 PM
Nawrocki4Life's Avatar
Nawrocki4Life is on a distinguished road
What that part may be...
Hello I am a service tech a company that used to deal Hardinge before they dropped us. I feel sorry for all the customers for now the knowledge of Hardinge equipment will dissappear soon.....
Its hard to say what that piece is exactly but if I had to guess from the pick. That is from the toolchanger's swing arm motor. That motor has a mechanical release for its brake. I believe that is the lever for that componet. climb up top of your machine and look at the motor directly above the swingarm. there should be a slot on the fan cover of the motor.... I bet it came from there.....good luck my man!!
Old 04-16-2010, 06:54 PM
just for your info
If you ever take a pic to show something else like this... its always good to add something next to the part to scale it. Coins usually work well.... like a penny or such. From that pick that rod could be any size. Let me know if i helped any.
Old 04-22-2010, 03:40 PM
U hit it right on the head. It took a few days but someone finally got back to us with the same answer provided by you. It was killing me. Thanks a lot.
Bridgeport Needs Air? JQ_Quint Bridgeport and Hardinge Mills 4 10-25-2008 03:46 AM
Bridgeport DRO Pin Out bill south Bridgeport and Hardinge Mills 3 09-28-2008 03:52 PM
My Bridgeport Willbird Vertical Mill, Lathe Project Log 48 01-21-2007 10:08 AM
Bridgeport TC 1G Jeff Mckay Bridgeport and Hardinge Mills 1 12-18-2006 05:37 PM
$400.00 Bridgeport Jarwalcot Bridgeport and Hardinge Mills 1 09-01-2006 08:06 AM
