Old 04-07-2010, 12:46 PM
PaulDSS is on a distinguished road
Convert Pnuematic Speed and Brake to Manual
I have a Bridgeport Series 2 CNC mill that I am in the process of updating to use in my home shop. This machine has a pneumatic speed and brake controller. Maybe this was a nice feature in it's day but I would rather have a manual speed selector wheel and a manual brake.
Do you know if it is possible to convert these pneumatic controls to a manual control. It looks like there are so many similarities between the various Bridgeport models that it might be possible to purchase a few parts from a different model to convert it.
Let me know if you have any sugestions about what parts I would need or if this is even possible.
Old 04-08-2010, 08:52 PM
Sparky_NY is on a distinguished road
I did it on my series one head. The basic config. is the same as the manual head. I just removed the brake cylinder assy and put on the handle from a manual head. The speed control air motor and the complete speed dial assembly removed and was replaced by the manual machine parts. Of course the series2 might be differrent. I would compare yours to a series 2 manual head. A exploded parts diagram would be helpfull.
New Machine Build- 600mm Box bend brake (Finger Brake, pan Brake) RotarySMP Bending, Forging,Extrusion... 20 09-06-2010 10:56 AM
Easiest way to convert HF 8x12 lathe to variable speed control sunnyday Mini Lathe 2 09-01-2009 10:24 AM
Need Help Looking to buy CNC lathe or convert a manual cybor462 Want To Buy...Need help! 1 02-28-2008 12:59 PM
Help with press brake manual... Experts needed. rjahr Bending, Forging,Extrusion... 11 02-10-2008 04:41 PM
convert rf45 type to belt variable speed and some cnc info? ataxy Knee Vertical Mills 20 09-03-2006 10:58 AM
