Old 03-26-2010, 08:52 AM
samu's Avatar
samu is on a distinguished road
Should i warm up the spindle
I have a hardinge vmc 1000 8k spindle(almost always running at 8k rpm). Should i warm up the spindle before making chips?? Actualy i let it turn at 2500 rpm about 20 min before machining. Is it a wast of time?? Does it only add some run time on the spindle bearing?
Old 03-26-2010, 04:52 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Its not a waste of time if you intend to put significant load on the spindle. If you are taking light cuts that don't even register on the load meter you can probably get away with it.
You may want to write a warm-up program that gradually increases your spindle speed to the normal running speed over that twenty minute period - and if you feel that you should warm up the spindle you could kill two birds with one stone and warm up the other machine axes as well. We use our program (called with an M-code) to warm up the machine at the start of the day and wash it down at the end of the day (with auto shut-down). Works well.
DP
Moderator
machintek is on a distinguished road
If it was my spindle, I would be doing the same thing.
George
Old 03-26-2010, 06:05 PM
holbieone's Avatar
holbieone is on a distinguished road
you should warm up your spindle all the time
one reason is spindle growth do to heat , a cold spindle will cut a few tenths to a few thousands different than a warm spindle
another reason is the grease in the bearings , when cold the grease is thick and is push out of the bearing path , when warm the grease is liquid like oil and will flow back into the bearing path
Old 03-27-2010, 11:52 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
Definately. Always warmup.
I wrote a prog for mine that warms up the spindle, and both axes on my lathe and my mill (they come on automaticaly in the morning).
Coldness is your enemy- a 100mm (4") iron rod will expand by 0.012mm (0.00047") at a temperature change of 10 deg C.
Your machine in the morning is essentialy a big lump of cold metal with cold oil inside it.
I love deadlines- I like the whooshing sound they make as they fly by.
Old 03-30-2010, 12:42 AM
M99 Dan is on a distinguished road
Always, Always warm up. Just like before going on a long bike ride or jog. It gives the machine a chance to lubricate itself, steel to grow and settle and you can go and make yourself a pot of coffee while you wait. christinandavid has a good point. Start slow and work your way up. Warming up all of the axis is very beneficial as well. My Kitamuras won't even allow a job to run unless they have been warmed up. 20 minutes minimum @ 5000 rpm or they just alarm out.
Dan
Old 03-31-2010, 07:14 PM
tacdriver is on a distinguished road
So what is a good warmup routine? I've been doing 1K rpm for about 1/2 hour. No table motions, though. Machine is usually at about 45 to 50 deg. F most of the year.
Should I write a program to step up the rpms? Say, 500/1000/1500/2000/2500 so about every 5 minutes it bumps up a level?
I am more concerned with bearing life and being kind to the machine than 2/10,000 tolerances as most of our parts have tolerances that are easy on us.
Spindle Warm Up Program stang5197 Haas Mills 5 03-29-2011 01:13 PM
X,Y,Z warm up. I am not a programmer... hrhoward Haas Mills 2 01-13-2010 08:45 AM
Fadal Spindle getting warm beyegladcnc Fadal 2 06-17-2008 07:50 PM
Warm-up program chuy Fanuc 1 12-11-2007 10:10 PM
Warm Up fadalman Fadal 1 09-15-2007 11:24 AM
