Old 03-24-2010, 09:49 AM
Shanghyd is on a distinguished road
Help identify missing electrical component
I'm having some issues with my bridgeport. In another thread I'm trying to work out a servo problem. During the process I found a space where it appears a part was installed at the factory.
Next to the space is a diode that only has one wire going to it. Wire number 113.
Anyone know what is missing/ The wiring diagram in my other thread shows this area.
Old 03-24-2010, 12:00 PM
gus gus is offline
gus is on a distinguished road
re
the answer is '5'
how about telling us what machine it is, preferably in the title so the right people will read it.
Old 03-24-2010, 12:16 PM
andyb4 is on a distinguished road
The part with the one wire appears to be a bridge rectifier (REC). It should have a pair of AC supply wires, usually on opposite sides(corner to corner) and two DC feed to a regulator (REG). This will supply the 24 volts DC to the machine. Note: If you have a 24 volt DC power supply somewhere else,(non-factory) this may not be needed.
Old 03-24-2010, 05:49 PM
Moderator
machintek is on a distinguished road
Looks like a very old interact machine with a Heidenhain control.
That is a bridge rectifier. Just to the right is a "bread-boarded" voltage regulator. Later they more sophisticated and had a nice enclosed 24VDC power supply.
George
Huanyang VFD HAL Component scotta LinuxCNC (formerly EMC2) 1 08-31-2011 10:53 AM
Missing a PC Board on Interact. Can you help identify? zmaker Bridgeport and Hardinge Mills 4 12-20-2009 04:13 PM
Tree 310 (Need help identify missing part) elnerdo Tree 3 04-02-2008 07:54 PM
component pricing gerrywelshman General Metalwork Discussion 0 05-18-2007 02:31 PM
Component failure len General Electronics Discussion 24 12-10-2005 10:04 AM
