Old 03-22-2010, 09:09 PM
salvador781 is on a distinguished road
TOOL CHANGER FAILURE
NEED HELP
I HAVE A BRIDGEPORT INTERACT 412 AND HAVING TROUBLE WITH THE TOOL CHANGER I SUSPECT THAT I HAVE A WRONG PARAMETER BUT NOT SURE WHEN THE CARROUSEL APROACH THE SPINDLE IS ABOVE 2.5 IN. FROM WHERE IS SUPOSSED TO BE AND IS NOT CLEARING THE TOOL HOLDER SO THE CARROUSEL TURNS WHITHOUT CRAHSHING WITH THE TOOL HOLDER
CAN SOMEBODY PLEASE
HELP ME
THANKYOU
SAL
Old 03-23-2010, 09:51 PM
Mark McDade is on a distinguished road
Tool Change Position Setup
Here are the instructions as copied from a sheet I got from Bridgeport. I'm only familiar with the TNC-15x control but these instructions cover other controls, too. Note that the parameter numbers do not show up in the Heidenhain manual because these are generic 'position values' which may be used by the OEM in any way they wish when the PLC logic is written.
1. Put a tool holder in the spindle.
2. Turn off the air.
3. Select the REF positioning display on the control (TNC) (Machine position on a Fanuc OM mate MF).
4. Adjust the position of the Z axis using the handwheel, so that when the carousel is pulled forward it engages the tool holder, at the correct height. (There is a picture of this which shows more engagement on the bottom of the toolholder groove (almost touching) and a slight gap on the top of it rather than having the carousel ring dead centered up and down in the toolholder groove. It looks as if the carousel is 'drooping' slightly when it touches the toolholder.)
5. Enter the figure displayed in the Z axis display into the relevant parameter, for the type of control fitted:
TNC 15x or 35x - parameter 126
TNC 2500 - parameter 4210.0
OM MATE MF - parameter 737
At this point, I think I would want to run a couple of tool changes with no toolholders just to be sure - this thing can do some damage if it is offset (I know this the hard way!). It would also be a good idea to save the params after this - or, at least, write down the z-height after you have verified it.
Hope this helps.
Mark
Old 03-25-2010, 12:13 PM
MARK THANKS FOR THE HELP I WILL TRY THAT AND HOPES IT WORKS BY THE WAY THE IN THE OPERATING MANUAL IT SAYS THAT MY MACHINE CAN BE EQUIPPED WITH 351A OR 355A BUT I'NOT SURE WHICH IS ON MY MACHINE
THANK YOU AGAIN
SAL
Old 03-25-2010, 12:50 PM
You're welcome.
Sal,
You're welcome! I believe that the 351 has no graphics and the 355 has graphics capability so that it shows the toolpaths that will be executed.
Mark
Hoss 16 Tool Automatic Tool Changer hoss2006 Benchtop Machines 316 03-03-2011 03:29 PM
Need Help!- Tool Release Piston Failure? JoBwan Haas Mills 4 07-30-2009 05:35 AM
VF2 SS tool change failure omy005 Haas Mills 2 07-09-2009 02:39 PM
Tool unclip failure Shotout Haas Mills 4 08-09-2006 08:03 PM
Tool Turret Index Failure hatchmar Machine Problems, Solutions , Wireless DNC, serial port 6 06-09-2005 06:36 PM
