I burned up a driver board and recently purchased another. Prior to the driver board burning up I was getting a gross position error on the z axis. I removed the z axis motor and cleaned out the carbon, checked the brushes and did a physical inspection of the armature. Everything looked good so I put it back together. It ran for a while then burned up the board. So now I've installed the new driver board and want to verify the wiring to the servo. I took the cover off another servo but the numbers are different. If someone can provide a schematic for the z axis servo wiring at the motor I would really appreciate it. I tried the Heidenhain site and couldnt find what I needed. I don't want to power up the machine until I'm sure of the wiring. |
| Is this a DC servo?, About the only way you would destroy a drive is through the armature. If DC, try it on a automotive battery, both directions and also test for ground on the armature connection. Al.
| I haven't had a chance to test the servo with a battery but wanted to describe a few more symptoms that I noticed. This board is doing the same thing as the last one that burned up. When the z axis retracts the transformer will rattle and hum loudly. Its only on the upstroke of the z axis that the transformer rattles. When I jog the z axis there is a definite difference in the speeds. Down is slow. Up is smoking fast. I noticed that when I was running a pecking cycle the z would retract very fast. I thought that it was because the up movement was rapid and the down movement was at the feedrate. The x and y jog at the same rate in either direction |
| The JOG joy stick will move down slower and up faster. It is for your safety. But rapid moves commanded in a program should be the same speed up or down. George
| I've attached a wiring schematic. I swapped out L2 and L3. No difference. Where should I take measurements to do my tests? I suspect its the servo. Edit: I think I need to tune the servo to the board. My maint. manual has instructions so I'm going to try that first. Last edited by Shanghyd; 03-23-2010 at 11:20 PM. |
| I pulled the servo motor off. Its a MT30R4-58. I have 3.8 M Ohms between the motor terminals and the housing. I measured each seperately. I put the meter leads in the motor terminal blocks and spun the shaft by hand. I got some output that was relative the the speed of the shaft. |
| That last post of mine was all wrong. Here's the latest. The X and Z axis are Controlled Motor Technologies (CMT) servos. The Y axis is a SEM servo. The specs are: CMT: 140V 37amps SEM 145V 32amps. I should be getting a resistance reading of 4.53 on the SEM motor and 3.78 on the CMT servos right? My readings are: SEM = 3.3 CMT = 2.0 (both are exactly the same) The resistance readings are off according to an Ohms law calculator I found on the internet. Any ideas about how to solve the issue or what could be causing the low resistance readings? |
| Very hard to measure the armature resistance using a meter, the accurate way is to apply a low voltage with a locked rotor and measure the current. Brush resistance and brush contact have an effect on a ohm meter reading. Did you tune the drives? Al.
| Need Help!- bridgeport interact 720 | foseguera | Post Processors for MC | 5 | 01-17-2010 10:04 PM |
| Bridgeport Interact 412 | Gncc50 | Bridgeport and Hardinge Mills | 2 | 02-02-2009 07:09 PM |
| CNC Bridgeport II interact 4 Tnc 150 | frenk59 | Bridgeport and Hardinge Mills | 12 | 08-06-2008 07:49 AM |
| Bridgeport Interact 316 VMC | L. Sakthivel | Bridgeport and Hardinge Mills | 2 | 05-05-2007 09:07 AM |
| Bridgeport Interact 1 MK2 | Leyland 472 | Bridgeport and Hardinge Mills | 3 | 10-20-2006 06:44 AM |
