Old 04-28-2005, 09:13 AM
zcases's Avatar
zcases is on a distinguished road
EZ Trak Plus - G code mode?
We have an EZTrak Plus at work.......P/N 15722R Rev A, S/N EP-129-P4330. We are evaluating some cam software and would like to be able to post to this control. Can it be done? Is there a secret button sequence that will "switch" it into g code mode? We can save a program by RS232, and it looks like some conversational stuff but no standard G or M codes. I would assume somewhere in the background the control is using G codes for the real motion control.
Anyone have any experience with posting to this control?
Thanks......
Scott
Old 04-28-2005, 11:49 PM
Jaguar is on a distinguished road
It reads Gcode without doing anything special. Check in the manual. When you are in the file manager press F4 and see if TXT files are read.
TM
Old 04-29-2005, 07:12 AM
Moderator
machintek is on a distinguished road
How old is this machine? Is this the EZTRAK PLUS with NO CRT? Over 13 years old?
George
Old 05-02-2005, 07:50 AM
zcases's Avatar
This is approximately 1989 vintage EZTRAK PLUS - no CRT, just a LED readout. I will try some simple G codes today and see what happens.
Old 05-07-2005, 10:26 PM
If it is the older SWI control I think you will be hosed.
TM
2 axis EZ Trak post? zcases Post Processor Files 3 12-18-2008 04:42 PM
looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft troyswood Ability Systems - LPT Indexer and G-Code 2 12-24-2006 09:21 PM
EZ Trak and G Code melamark Bridgeport and Hardinge Mills 23 05-05-2006 12:03 PM
parametric programming Karl_T CamSoft Products 21 05-24-2005 02:58 PM
Getting The Most Out of CNCzone's Posting Features CNCadmin CNCzone.com FAQ 0 03-01-2003 11:08 PM
