Old 03-20-2010, 02:58 PM
dcchip is on a distinguished road
bridgeport series 2 interact 4
Hello I had a bad 24 volt power supply(this is the one on the right as you face the side cabinet)coutant hsh60u-13 and I had a guy try to fix it with a generic he had and I dont think he knew what he was doing and created different errors. He told me to send control to heidenhain (tnc 2500) and 350.00 bucks later was told control was perfect x!!##$$*. I am starting back at square one and I went ahead and bought the correct one off e-bay but I didnt see how the wires came off the original. Does anyone have one of these beasts and tell me what wires go where. And could you give me the correct tool holder and retention knob size. The manual said iso 40 is this the same as a cat 40? P.s I have a maintenance manual and parameters for control if I can make copies to help anybody.
Old 03-22-2010, 12:40 PM
Moderator
machintek is on a distinguished road
Attached is a Bridgeport service bulletin 277 that may answer your question.
George
Old 03-23-2010, 06:06 PM
Thanks That'll give me a good chance of figuring it out!
Old 11-15-2010, 04:47 PM
jonnyiwright is on a distinguished road
Interact 4 series 2 parameters
Hi dcchip
I purchased this gigantic beast a few months ago and can't wait to get machining! it has a broken power supply on the back of the tnc 145 I have built my own PSU out of atx psu and extra bit of my own, and now it is up and running I need parameters could you post yours please
Thank you in advance there doesn't seem to be parameters anywhere for the interact 4?
You will Really pull me out of the sticky stuff
Jonny
Bridgeport Series II Interact 2 problems gugu Bridgeport and Hardinge Mills 24 01-10-2011 07:34 AM
Need Help!- Bridgeport Series 2 Interact 2 Feedback jaytam Bridgeport and Hardinge Mills 4 09-06-2009 10:28 AM
Need Help!- bridgeport interact 4 series 2 gideon233 Bridgeport and Hardinge Mills 3 02-15-2009 08:05 PM
Need Help!- Bridgeport Series 1 interact tnc 145 jaztau Bridgeport and Hardinge Mills 2 10-20-2008 04:12 AM
Need Help!- Bridgeport Series 1 Interact zorba99 Bridgeport and Hardinge Mills 7 06-11-2008 07:59 AM
