Old 03-17-2010, 06:57 AM
TbcSEOD is on a distinguished road
Boss 5 mill, Air valve voltage and spanner wrench
Hi all, I have a BOSS5 that I have up and running (and am thoroughly impressed with) but the last thing to be fixed is the air cylinder valve - I need to find out the proper voltage that the valve operates on? It is completely disconnected from the machine currently and I would like to hook it to a simple on off switch t trigger the valve to open/close manually when needed.
Second thing is the Locking nut on the spindle (Erickson QC30), I do not have a spanner for it and am wondering if any one knows where I might find one to fit that nut? I made a home made one and it works "ok" but I am afraid it might round the groves over time and then make it even harder to properly tighten.
Thanks in advance for any assistance.
~Terry
Old 03-19-2010, 08:02 AM
keebler303 is on a distinguished road
I think the valve is 120V, not 100% sure though.
My wrench is from erickson, I don't know if they are still available or not. I am sure you can get them from somewhere. In the mean time, I doubt your home made one will cause a problem. The nut seems fairly hard from my experience.
Matt
Old 03-19-2010, 10:33 AM
Moderator
machintek is on a distinguished road
Per a schematic, it seems that the speed increase and decrease and the brake are all 24 volt devices. A meter can verify that yours is the same and has not been modified.
George
Need help with programming a spanner wrench Shanghyd Bridgeport and Hardinge Mills 8 12-17-2009 12:09 AM
BOSS 4 Voltage Stabilizer tsquint1138 Bridgeport and Hardinge Mills 0 03-23-2009 09:02 AM
Duty of the spanner nut on X2(mini mill) ZipSnipe Benchtop Machines 4 06-08-2006 11:05 PM
NMTB30 wrench / spanner? damae Bridgeport and Hardinge Mills 7 12-14-2005 03:45 PM
anyone know what size spanner wrench? jderou Bridgeport and Hardinge Mills 3 06-03-2005 08:01 AM
