Old 03-15-2010, 10:34 AM
RMT41 is on a distinguished road
Question Series I Interact 151 spindle want starte
Hi I have a series I interact with 151 control have been running for over a year went to start this morning it went tru all the homeing and powering up just like always but when I tryed to run program that I had all ready ran once friday with no problem and try to turn spindle on it turned on for just a sec. and then the power on controler reset it self like it lost power no fault on control any ides I checked all fuse and reset on motor contact still will not turn on.
Old 03-15-2010, 05:58 PM
gus gus is offline
gus is on a distinguished road
IS it on a phase converter?
sounds like low power on the leg with the control on it
Old 03-16-2010, 06:39 AM
Gus
It is on 3 ph 208 volts and all 3 legs are the same it is working now not sure what was going on maybe the power supply is getting weak or just gremlens.
Old 03-16-2010, 09:47 AM
Moderator
machintek is on a distinguished road
Bad float switch in oil tank?
Power supply runs the relays so it would not even home if it was bad. No 24 VDC = EXT relay voltage missing when control fires up.
Control works on 115VAC I think.
George
Bridgeport Series II Interact 4 Spindle Brake UKRobotics Bridgeport and Hardinge Mills 6 04-27-2009 12:22 PM
Need Help!- BRIDGEPORT SERIES 1 INTERACT SPINDLE REPLACEMENT INSTRUCTIONS RMARCH Bridgeport and Hardinge Mills 1 03-09-2008 04:04 PM
Newbie- Interact 1 Series ll JRS Bridgeport and Hardinge Mills 2 02-01-2008 06:21 AM
Identifying Bridgeport Series 2 Interact 4 Spindle Motor UKRobotics Bridgeport and Hardinge Mills 2 05-26-2006 06:55 AM
BP Series II Interact IV spindle causing machine to reset. ronmarkum Bridgeport and Hardinge Mills 1 01-25-2006 12:58 PM
