Old 03-15-2010, 09:53 AM
ichudov is on a distinguished road
Weight of "Bridgeport Series II Interact 2" milling machine
I need to know, fairly accurately, the weight of "Bridgeport Series II Interact 2" milling machine. I need it in order to securely handle it, specifically I want to make a base for it on casters. I want to pick the right materials to make the base that would handle the weight.
And definitely I do not plan on operating it on casters -- I would prop the base with 2x4s to relieve casters and make the mill secure. But I will need to move it as I work on it.
So... anyone knows how much these machines weigh?
Old 03-15-2010, 11:50 PM
jmelson is on a distinguished road
Series II NON-CNC machines are listed as a shipping weight of 4750 Lbs. in one catalog, in another it is 5500 Lbs. Their 1974 catalog lists the Series-II CNC at 7200 Lbs shipping weight. This is a TAPE NC system, with a separate cabinet for the control. I'm guessing this even predates the BOSS control. Your machine is probably a bit less than that.
Jon
Old 03-19-2010, 10:37 AM
Moderator
machintek is on a distinguished road
Per manual 11040804 for a Series 2 R2C3 with a TNC 145 control (same as a interact 2 series 2 but made here and not the UK) the gross shipping weight with skid was 5500 pounds and height was 96 inches.
George
Old 03-23-2010, 04:21 PM
Shanghyd is on a distinguished road
I'll believe the 5500 lbs. I bought mine in Houston and towed it home with an GMC Envoy and a tandem axle trailer. Nightmare.
Newbie- First Machine HELP...24"x36"x4" or Larger Setup w/ Gecko for under $3000 buschhoff Want To Buy...Need help! 4 03-20-2010 06:37 PM
"Gross Postioning Error A" Doing M03 on Bridgeport Interact Series 1 Mk2 MeTri Bridgeport and Hardinge Mills 5 12-27-2009 11:37 PM
Newbie- How do I "Traverse Axis"? Bridgeport Interact 1 Mk2 TNC 155 MeTri Bridgeport and Hardinge Mills 5 12-27-2009 05:10 PM
Determining "speed hole" spacing and size? (weight saving cutouts) douglasco Mechanical Calculations/Engineering Design 8 08-04-2008 03:26 PM
Bridgeport Series "I" will not home, please help technical school in need!! phantomcow2 Bridgeport and Hardinge Mills 6 12-15-2005 05:11 PM
