Old 03-14-2010, 07:04 PM
racer6645 is on a distinguished road
Question V2XT Probe Installation
Hi all. I would like to attach a probe to my Early V2XT. I believe the software is there because If I turn the probe on A message states that the probe is in contact with something. I am assuming that there is a place to connect the wires to, but I have not found it yet, Can any one tell me where I can get the wiring information from? The only info. I have came from the Yahoo group and I have not found anything there about a Probe yet.
The Other Question is about the cable connecting the A and B communication ports together, what is it there for? I would like to use one of the ports to communicate with my PC.
Thanks In advance, Sam
Old 03-15-2010, 09:05 AM
Moderator
machintek is on a distinguished road
1, the wiring diagram should show the probe interface. There is a round plug on the casting covering the front of the quill where this plug is located if you have it.
2, are you talking about a black self contained plug on your RS232 DB25 connector? That reroutes the terminal signal to be displayed on the CRT. You can remove it for communications.
George
Old 03-15-2010, 10:28 AM
George,
1, Thanks for the quick reply. That's one of my problems --- I have no diagrams, can you point me to somewhere that I can get them? It has a 386SX processor. The serial # is XT144.
1, I took the cover off of the front of the spindle that covers the Z limit switches, but I see no unused wires, am I looking in the correct place? If this machine is not wired for a probe, Is it possible to install the needed conductors and make the system work?
2, There are 2 black connectors, one on each com. port, (A and B) with a cable connecting them together. There are 4 or 5 pins on each port connected together by the cable.
Thanks, Sam
Old 03-19-2010, 10:31 AM
Moderator
Stopped by my office (rare) and looked at maintenance manual 11042556 for the V2XT.
There is no probe interface shown on the schematic for the machine with a BMDC.
however, the machine with the BMDC a probe interface is shown as connector P3.
Cannot identify your Port a and B jumper.
Port A shows a transmit and receive (pins 14,15,16) going directly into the FMDC at K5, and the usual RS232 pin out going to the mother board. Could port B be a parallel printer port?
George
Mach Probe plug in what is "maximum z height for stuck probe" option do? Rich05 Digitizing and Laser Digitizing 7 04-11-2009 12:05 PM
OpenCAM Installation Help chaddcurtis OpenSource Software 3 01-25-2008 06:58 PM
Super Probe 17 Functions in one probe thegimpster PIC Programing / Design 0 01-25-2008 12:46 PM
E-Chain Installation mcyr DIY-CNC Router Table Machines 3 11-08-2007 05:01 AM
Need help with Ultra3000i installation..... Darc Servo Motors and Drives 10 07-19-2005 09:00 PM
