Old 03-11-2010, 07:48 PM
frontrange is on a distinguished road
Seized Knee Gib
I really faked up. I had the knee lock set and forgot it. So today I started playing with peck drilling, and after quite a few pecks, the machine knee seized up. As soon as I realized what happened I loosened the lock and started dousing the Vee way above the lock with PB blaster, but its locked up tight as a drum.
I tried freeing the gib from the top but the slotted part of the gib was broken off. I also tried to loosen it from the bottom but it won't budge.
Gawd I feel sick. Even if I get it loose somehow the casting must be gouged now. Any ideas?
TIA
Old 03-11-2010, 08:27 PM
HuFlungDung's Avatar
Moderator
There have been several discussions about this over on practical machinist forums.
Old 03-12-2010, 12:14 PM
After reading the post about complete disassembly and laying the column back to tap out the gib from underneath I was really feeling sick.
The story has a happy ending though, I just got the gib loose. I was thinking about jamming a rod under the gib, running the table back to the column, loosening the pedistal and raising it, then putting a bottle jack between the table and ram.
This morning when the factory opened I called Lagun and talked to a tech. He told me the way I planned was how they did it. Half hour later I had it done. No drama at all (at least till I got a quote on a replacement gib...) Whew!
Old 03-12-2010, 05:28 PM
Moderator
Good for you!
Old 03-12-2010, 05:41 PM
Thanks - I was really down this morning before talking to the Lagun tech. I'd just got a 4th axis installed as was really beginning to have fun with this machine till I broke it.
One thing is for sure, that knee lock handle is staying in a baggie from now on. I don't know why I didn't take it off long ago, I'm just too used to manual operation I guess. I can't believe those Servo motors can fast peck a locked knee. Funny I'd been thinking it would be nice to install some load meters on each axis. Guess I should get around to doing it now.
Old 03-12-2010, 06:19 PM
thebodger@roger is on a distinguished road
Yup,
Keep that lock in a baggie. Let the servos or stepper do the locking. I know the mechanical locks can improve stiffness, but they can also seize the gib, if the circumstance is provided.
Old 03-12-2010, 06:38 PM
I just wish someone had told me that before I broke a $400 gib. An expensive and stressful lesson that will not soon be forgotten.
Old 03-13-2010, 09:33 AM
Moderator
machintek is on a distinguished road
The only Bridgeport that used the knee was the old S2NC. And it had a air over oil quill feed for drilling to keep knee action to a minimum + a air assisted knee.
Typically there is also a automatic oiler that pumps a shot of oil about every 20 minutes or so to the knee. Does your machine have that? Is this a conversion?
When ordering a gib from Bridgeport, you received a raw gib unless you specified the size and paid for the scraping and oil grooves to be put in. just in case you need to know this.
George
Old 03-13-2010, 09:50 AM
Actually its a Lagun FTV-2. I was told by the tech at Lagun that they only made a couple of machines with a ball screw under an air assisted knee and fitted with a Servo II system - I have one of them thanks to a lucky buy on Ebay.
And yes it has an auto lube system as well.
I was told the scraping needed would be minimal - I do know I need to do the oil groove and adjustment screw slot too.
Old 03-13-2010, 10:22 AM
mactec54 is on a distinguished road
frontrange
You can repair the gib that came out & put a new piece on top, that is why it jamed up to start with, the piece that was missing off the top is what holds the gib in place,without it the gib will slide down & jam the knee, it was nothing to do with the knee being locked that made it jam, Just the gib missing it's retainer, with the peck drilling it was able to pull the gib down
Mactec54
  #11   Ban this user!
Old 03-13-2010, 10:29 AM
I know the retainer losing it's grip on the gib when the top broke off was when things went south, but of course that happened because the gib was locked during a fast peck operation in the first place.
How would you repair the gib?? I assumed this is cast iron as it is very brittle. I guess you could heat/braze and cool slowly but it hardly seems worthwhile since it could still have cracks that would get you back into the same problem all over again...
  #12   Ban this user!
Old 03-13-2010, 03:11 PM
frontrange
The knee on your machine was no designed to do peck drilling, just smooth up & down movements, There are a lot of different way's to repair the gib, one you can just mill a new slot in it for the ajusting screw & then you have to glue a shim on the back of the gib, the whole of the back needs to have the shim on & shaped the same as what the gib is, If you went with welding it you would have to bronze weld it, stick weld it you could get cracking as you said, you could mill a flat on the back of the gib & attach a stepped steel plate/block & screw/bronze this in place it won't crack if you braze it properly
Mactec54
Build Thread- Old CNC knee to MACH3 extsuba Vertical Mill, Lathe Project Log 5 12-18-2009 11:34 PM
Pulling Seized Shafts KSUsenior Mechanical Calculations/Engineering Design 2 04-07-2007 10:03 AM
Seized and broken bolt removal Caprirs General Metalwork Discussion 12 12-07-2006 10:26 PM
Knee thingy Steve@Reliance Bridgeport and Hardinge Mills 4 08-25-2006 06:52 PM
Knee retrofitting m_c Knee Vertical Mills 10 02-27-2006 03:12 PM
