Old 02-28-2010, 10:24 AM
Ranchero50's Avatar
Ranchero50 is on a distinguished road
More X for a Discovery 308?
18" of x is just a little bit too short. Been thinking long and hard about this and luckily the machine uses bolt in linear rails. I looked under the splash covers and I can extend the rails 4.25" on each end and probably get the same sized ballscrew, reset the limits in the program and get @25-26" of travel out of this thing. The rails bolt to the table, the bearings bolt to the Y axis frame.
I'm thinking the deal killer will be the ball screw pitch. I'm sure the linear rails are still available even if expensive (we use them at work on the machines)
Opinions?
Jamie
Problem- BRIDGEPORT DISCOVERY 300 ANTONIO OCHOA G Bridgeport and Hardinge Mills 0 05-20-2008 08:09 AM
Bridgeport Discovery 308 jdfelice Bridgeport and Hardinge Mills 0 09-13-2006 06:43 PM
Discovery 308 Servo amp gzero Bridgeport and Hardinge Mills 0 04-11-2006 11:10 PM
Discovery 300 needs service in WI scnolan14 Bridgeport and Hardinge Mills 6 02-22-2006 12:44 PM
Massive 5-axis on Discovery! svenakela CNCzone Club House 1 08-05-2004 07:42 AM
