Old 02-27-2010, 11:05 AM
ichudov is on a distinguished road
When was my Bridgeport Series II INteract 2 made
Would appreciate knowing.
The serial number is 509261288B
Thanks a lot!
Old 02-27-2010, 10:35 PM
Moderator
machintek is on a distinguished road
Might be easier to figure out by the type of Heidenhain control.
George
Old 02-28-2010, 12:25 AM
George
TNC 151
Old 02-28-2010, 08:44 AM
Hood is on a distinguished road
If they are numbered in the same manner as my UK built series 1 then its a 1988 machine, mine is 81B which as far as I understand is 1981.
Hood
Old 02-28-2010, 12:12 PM
Moderator
I was installing TNC151 from about 1987.
Hello Hood.
George
Old 02-28-2010, 03:34 PM
gridley51 is on a distinguished road
I`ll need to look at the serial numbers of mine.I have an Interact 11,Series 11 which is a 1984 machine with a 145 control.The other is a Interact 1,Series 1 with a 150 control.
Would the serial numbers run across the models including ones built in the UK and USA?
Was there an order in which things progressed or did they build different models at the same time or was it just down to what the customer ordered?
I know that the head support arm although looking the same on the Series 1 and 11 is different and I think the Ser 11 has a through hole in the spindle.
I`ve never been that much interested in Bridgeports but over here at the moment they are a cheap machine to buy.
Mark.
Old 05-23-2010, 09:57 AM
sohail_lio is on a distinguished road
hi i am use machine Bridgeport Series II Interact 2 tnc 150b
machine is on display show operation parameter erased CE CLICK no MPOO LINE...........
WHAT SHOULD I DO?
Old 05-23-2010, 11:33 AM
Moderator
Check the batteries. Load parameters.
George
Old 05-29-2010, 03:56 PM
WHAT SHOULD I DO?
my email id sohail_lio@hotmail.com
Old 05-30-2010, 11:32 AM
Moderator
Replace parameter back up batteries and load parameters.
George
Bridgeport Series 2 Interact 2 Heidenhain TNC 155 rrossey Bridgeport and Hardinge Mills 9 05-16-2011 08:29 AM
Need Help!- bridgeport interact 4 series 2 gideon233 Bridgeport and Hardinge Mills 3 02-15-2009 08:05 PM
Need Help!- Bridgeport Series 1 interact tnc 145 jaztau Bridgeport and Hardinge Mills 2 10-20-2008 04:12 AM
Need Help!- Bridgeport Interact 1 MK2 some progress made BrianP Bridgeport and Hardinge Mills 19 08-15-2008 04:17 PM
Need Help!- Bridgeport Series 1 Interact zorba99 Bridgeport and Hardinge Mills 7 06-11-2008 07:59 AM
