Old 02-27-2010, 08:18 AM
csaw is on a distinguished road
Boss Machine Questions R2E3 etc
First of all what is the difference between R2E3, R2E4, R2C4?
I have seen two machines that are both Boss 8 and they look different. The big plastic front on one is about twice as big as the other with more controls. What's the difference?
PS where are all these machines that can supposedly be had for a song or for the hauling?
Old 02-27-2010, 04:59 PM
ichudov is on a distinguished road
How much do you consider a song?
i
Old 02-27-2010, 06:11 PM
I would consider the stories I see from free to $500 a "song". I don't actually expect to find one for that, but it appears others are.
EDIT: Should clarify, needing repair or retrofit.
Old 02-27-2010, 10:29 PM
Moderator
machintek is on a distinguished road
R2E3 Considered a BOSS 8. Available in series 1 and 2. 2 line LCD display made by epson.
Servo motors. Can DNC.
R2E4 BOSS 9. Has a CRT instead of the LCD. Newer than BOSS8. Otherwise basically the same.
R2C3 has a Heidenhain control and Bosch drives. Same iron as above.
George
Old 02-28-2010, 12:49 AM
Wink
Should be pretty doable, based on my experience. >):
i
Old 02-28-2010, 08:48 AM
Thanks Machintek, that's exactly what I wanted to know. Now ichudov, to find a DEAL in reasonable driving distance from Florida.
Old 03-04-2010, 07:27 AM
If in my searches I find a Boss 8 or better machine that is in good condition and in working order how much are they worth? My reason (and everyone elses evidently) for wanting to retrofit a machine is so that I can make repairs myself. My fears are that if I spend more on a working machine and it quits it will be expensive to fix and I may have to go with the retrofit and be out the extra money.
Is retrofitting a dead machine a better idea than buying a working machine?
Are the Boss 8s and such good machines when working properly? Expensive to fix?
bridgeport II/r2e3 boss 8 whaley Mechanical Calculations/Engineering Design 0 01-01-2008 11:02 PM
Need help on R2E3 Boss 81 sharp-shooter Bridgeport and Hardinge Mills 7 11-19-2006 10:42 PM
cnc R2E3 boss 8 off limits leftyrowe Bridgeport and Hardinge Mills 16 09-20-2006 09:27 PM
Problems with DNC to BOSS 8 R2E3 rkdygert Bridgeport and Hardinge Mills 0 04-17-2006 08:45 AM
Bridgeport R2E3 with Boss 8 John Bennett Bridgeport and Hardinge Mills 0 09-16-2005 07:35 PM
