Old 02-24-2010, 01:36 PM
progeny is on a distinguished road
tooling advice needed
Hi
I am running a hardinge xv1000 mill and I have a new job for it,
I need to bore 20mm holes and 32mm holes in commercial grade mild steel 30mm deep,can anyone suggest a tool that will do a lot of them and be reliable.
thanks
Old 02-24-2010, 06:10 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Choosing a Tool/Method
Your method will depend on any constraints/encumberances ie budget/time/machine/dimensional and positional tolerances.
You could u-drill the holes undersize then follow up with either adjustable boring heads to semifinish/finish OR circular pocket with a semi-finishing and finishing endmill OR a combination of both methods.
Obviously if tolerances and surface finishes don't matter a jot just bang a size u-drill in there and be done with it...
It really all depends on whats most important. You should aim to fulfill the following three important criteria: Good, Cheap and Quick. Remember though the general rule of thumb which is: -
If it is Good and Quick it will NOT be Cheap.
If it is Good and Cheap it will NOT be Quick.
If it is Cheap and Quick it will NOT be Good.
DP
Old 02-24-2010, 06:39 PM
CNC PGMR is on a distinguished road
I would suggest using the ISCAR "dz" style drills.
CNC diemaking shop needed to build tooling from my SolidWorks models PhoenixMetal Diemaking and Diecutting 18 01-19-2011 09:15 AM
Newbie- Just purchased Lathe, Need tooling advice. VanIsleDSM Mini Lathe 16 03-16-2008 04:59 PM
Tooling Advice Wanted Babba Engraving Machines 9 02-03-2008 10:38 PM
Advice requested on getting first mill tooling.. hotponyshoes General Metalwork Discussion 9 04-04-2007 10:48 AM
Tormach Tooling Feedback Needed snakebit95 General Metal Working Machines 11 08-02-2005 12:18 PM
