- Problem- ez-path,axis fault
ez-path,axis fault
x axis fault,i change the driver x on z and still the fail,check the motor impedance too (no short),limit sw tooi have a relay cr6 (lube motor) when i put in place,the breaker cb4 comes down(have 110vac),(i have to take off to work) and the machine dont come at homebut with jog + esc i put it at home,and if i push the #4,the screen sometimes send me to the jog screen,and then i can jogonly the z axis,and the spindle work too,(this after 3 days with the power off) anybody have a suggestion...thanks in advance
- You may not post replies
- You may not edit your posts
Forum Rules
