- Need Help!- Romi M27 Unwanted taper + other issues
Re: Romi M27 Unwanted taper + other issues
Well to anyone interested, all 100+ views and 0 replies. We got the taper out by leveling the machine, we adjusted the head stock then adjusted the tail stock. Now over 40in the difference is only .001 As for the other issue with the offsets, we've figured that we need to reference the machine after pretty much everything. Well that's problem solved in case anyone else has a similar problem with a Romi M Series.
- You may not post replies
- You may not edit your posts
Forum Rules
