hello, arrive late to respond, certainly had problems with the pneumatic cylinder, that system often fails to time.
regards
ROMI/BRIDGEPORT 35 ALARM -GEAR OUT POSITION HOW DO I RESET TO CLEAR THE ALARM
THANKS,
JIM
Got it figured out, if anyone else has
this problem, contact me.
Jim
regards
Good morning,
if you still with the problem, try to locate the engine of change range, uncover it, clean it and lubricate it, forcing manually the change.
The change is automatic? or via a "M" function
Good morning, if you still could not suppress your problem, try to locate the engine of change of range, uncover it, clean it and lubricate it, forzandolo manually the change.
