- Need Help!- EZ-Path Command Prompt
What is the easiest way to exit into the DOS Command Prompt window from the EZ-Path program? Or is there a way to get there during the Boot sequence? I know you can press DEL to exit into the Set-Up screen during boot up. I want to eventually get to the A: directory.
Re: EZ-Path Command Prompt
I have an EzPath II but this should be similar. Go to <9> Utilities <4> Comm. Press Control C then <Y> to terminate batch job.
You should now be in the C:\Ppath directory. Then of course type A: to get to A:. To get back to the EzPath screen type <ezpath>. All typing is without the <>. Just in case, pressing control C is holding the control key down and hitting the c key.
- You may not post replies
- You may not edit your posts
Forum Rules
