Romi/Bridgeport EZ-Path Lathe serial transfer using EZ-Path Utilities
Results 1 to 3 of 3
Thread: Romi/Bridgeport EZ-Path Lathe serial transfer using EZ-Path Utilities
    Jul 2013
    Default Romi/Bridgeport EZ-Path Lathe serial transfer using EZ-Path Utilities
    When I run the EZ Path Utility (9 key) to initiate a serial transfer from a remote computer, the program (.txt or .pgm) streams by on the screen
    as it's being received and the last line with AUXFUN M2 is visible at the bottom, but that's where the utility tool seems to freeze. When I press
    ESC, a message shows up saying the batch process was terminated, and there's no downloaded program. It appears the utility is still waiting
    for characters. How do I tell it the transfer is complete (i.e. store the program and exit back into the main menu)? Is there perhaps an End-of-file
    character missing (e.g. Haas uses % signs)? The transfer is over a serial line using TeraTerm (4800, 7 bits, even, 2 stop bits), which works fine
    on the older Bridgeport Mill. Your help would be much appreciated.
    Oct 2005
    U.S.
    Default Re: Romi/Bridgeport EZ-Path Lathe serial transfer using EZ-Path Utilities
    Did you ever have any luck getting this working?
    Replace the diskette drive with a usb diskette emulator, they cost about $30. Copy your files on a thumb drive and read them directly into the machine.
    Steve
