I've machined a fair bit of cast iron and it was always, without option, machined dry.
We used dust extract and filtration to handle the dust as it is a fair health hazard if not coped with.
We're running the same product on these lines. A couple of the operations create these very fine chips that end up creating a mud-like sludge on the screens and hinder coolant flow. Has anyone dealt with this issue before? Our line is in the middle of a several hour long cleanup process. I'm looking to some solution to this to avoid having to do it in the future.
Some details:
We only run gray-iron castings on this line. The graphite in the gray iron is less magnetic and I believe this is the bulk of the sludge avoid our magnetic conveyor.
We use a magnetic chip conveyor which seems to collect only the large chips, I don't really see any of the sludge get in there.
If anyone has dealt with this issue and found resolution I'd love to hear how it played out.
Thanks!
Bending bits of metal in Hertfordshire - https://ddmetalproducts.co.uk
One way to handle that is a moving fine screen conveyor, with a backwash system to clean the screen. I think these are commercially available or pretty easy to build. I have also seen a centrifugal solids separator. We used to use what was like coffee filter material that was on a roll, when it started plugging up, you just pull some fresh material into place and toss the used piece in the trash.
Jim Dawson
Sandy, Oregon, USA
