Need Help! DX32 Torq Cut 22 HSM Adapative
Results 1 to 6 of 6
Thread: DX32 Torq Cut 22 HSM Adapative
    Dec 2017
    Default DX32 Torq Cut 22 HSM Adapative
    Hello again.
    from one problem to the next lets get this machine dialed in!
    I was test cutting a part today on the machine and ran into a hiccup
    using Inventor HSM much like Fusion 360 and using an updated post processor for the machine,
    there seems to be a issue when loading an adaptive clearing program.
    facing operations work flawless
    pocket with helix ramping and all the goodies works flawless
    when I load an adaptive the program gives its preview like normal and when asked to write to CNC I hit yes
    and then get an ' Error in LOAD CNC!! '
    I have a feeling this is another minute detail that i am missing for this application but would like the communities opinion on the matter.
    attached is the error, a sample of adaptive program, and a sample of pocket program.
    and then attached is also the programs themselves
    lets problem solve!
    Attached Thumbnails Attached Thumbnails DX32 Torq Cut 22 HSM Adapative-20171213_165506-jpg   DX32 Torq Cut 22 HSM Adapative-20171213_165455-jpg   DX32 Torq Cut 22 HSM Adapative-20171213_165540-jpg
    Attached Files Attached Files
    Dec 2017
    Default Re: DX32 Torq Cut 22 HSM Adapative
    Problem Solved! again lucky to have an easy fix for this!
    so! Changing the very first line in the code to a " < " solves the problem. Im a little stumped as to why because other programs I have loaded have matching code but that little thing makes the old DX32 happy!
    compare line one in picture
    Attached Thumbnails Attached Thumbnails DX32 Torq Cut 22 HSM Adapative-dx32-code-jpg
    Member jmullett's Avatar
    Nov 2004
    I don't know what crazy ASCII character at the beginning of your programs even is, but not necessary. Your real problem is you are right up against the 256KB limit. Larger files have to be dripped fed using the <F10>SET DNC function key in the run menu.
    Dec 2017
    Quote Originally Posted by jmullett View Post
    If you can consider that a problem lol I had no problem with functioning in my tests doing drip feed from large files
    as far as the crazy character I cant find were it's being entered in the post processor so I'm not sure how its getting there I'll keep looking at the code.
    I got a full arsenal of Helical brand tooling coming along with Techniks face mill and Haimer 3d Sensor
    looking forward to see how hard this little machine can be pushed!
    Dec 2005
    Quote Originally Posted by tw1st3d View Post
    Over the summer I re-worked the DX32 post processor for Fusion 360. It has been working well. I haven't checked the HSM post processor thread in a while to see what changes have made it into the generic post. You might try mine and compare.
    http://www.cnczone.com/forums/bridge...dx-32-a-4.html
    http://home.lewiscounty.com/~forhire/posts/
    Dec 2017
    My my post is working great so far here some pics of results of some xmas inspired trial runs.
    Ill give your post a run through and compare it
    Attached Thumbnails Attached Thumbnails DX32 Torq Cut 22 HSM Adapative-20171222_021248-jpg   DX32 Torq Cut 22 HSM Adapative-img_20171221_192846_729-jpg   DX32 Torq Cut 22 HSM Adapative-img_20171218_181128_017-jpg
