Partly solved the problem. Parameter 10 was zero it should be 7. Now axis are showing. But I get an error message X axis drive fault. It appears not to be enabled.
I have been told that 3CR led should be lit but its not. The drive card is a Bosh Z15 anybody have info on what voltage and terminals to enable the drive?
