Does anyone have the procedure to adjust the backlash compensation torq cut 22 with DX32 control? Since I had my X ballscrew repaired I now need to adjust the backlash.
I know that it needs adjusting because it will not interpolate a round hole. They are at least 1.5 to 2 thousands out of round.
In my Installation , Maintenance and Parts Break Down Manual I see on page 7-12 a method for setting the lead comp on all axis. Basicly you tell the table to move 10 inches and then measure and tell the computer exactly how far it moves. That is <0,3> Set Lead Comp. I would think you need to do that first on the new screw. THEN
Right above it is <0,2> Set Backlash. I would do this after setting the lead comp...
All this is done on the maintenance page in the control, my password is 007 for that page..
