Bridgeport Ez Trak Plus encoder help.
Results 1 to 3 of 3
Thread: Bridgeport Ez Trak Plus encoder help.
    Aug 2017
    Default Bridgeport Ez Trak Plus encoder help.
    Im looking for help, I have a Bridgeport Ez Trak Plus with CMC servos (MTE4225-157g2f). I encountered a problem where the y-axis wasn't registering on the screen, checked cables, connections, etc. Then I went ahead and swapped encoders from the one working axis to another. So I narrowed it down to the encoder. Its a RENCO encoder (14414-557) I haven't been able to find a replacement ANYWHERE. Maybe someone can point me in the right direction with a replacement or equivalent? Thanks in advance!
    Apr 2013
    Default Re: Bridgeport Ez Trak Plus encoder help.
    Call EMI, they can get you a replacement motor... 610-287-4240
    Jonathan Bass
    H&W Machine Repair and Rebuilding Inc.
    Dec 2003
    Have you tried Renco, they have less models now since taken over by Heidenhain, but they used to be very helpful, what are the physical and output details of the encoder? Is it through hole or shaft type?
