Newbie Recently Purchased Series II, can i run it with a VFD?? - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 63 of 63
Thread: Recently Purchased Series II, can i run it with a VFD??
  1. #61
    Dec 2003
    Default Re: Recently Purchased Series II, can i run it with a VFD??
    You may be able to use a large treadmill motor, 2.5 to 3.5HP.
    May 2017
    Well, looks like bad news for the motor. I tore it apart again just to double check my work, and didnt find any issues, however when using my meter, there is some continuity to earth from the commutator. I can assume this means its got some bad insualation somewhere in the windings, causing a short to ground. Off to the motor shop she goes.
    Levi
    Proud owner of a new to me Bridgport Series II
  3. #63
    Dec 2003
    If you have it rewound, then at least they will fit a new COM if available.
    Al..
