Local time on the Heidenhain iTNC530
Results 1 to 2 of 2
Thread: Local time on the Heidenhain iTNC530
    Feb 2017
    Russian Federation
    Default Local time on the Heidenhain iTNC530
    Where and in what parameters to look local time on the rack Heidenhain iTNC 530. System HeROS. Can you give an example of how to correctly use the command CM 9055
    Dec 2011
    Hungary
    Default Re: Local time on the Heidenhain iTNC530
    #type D
    DG_real_time
    #type S
    SG_time
    #type K
    KG_format_time_h_m_s 13
    PS DL_real_time ;Number of seconds since 0:00 hours on January 1, 1970.
    PS K &SG_time ;String number for the result
    PS KG_format_time_h_m_s ;Format (13: hh:mm:ss)
    CM 9055 ;Convert time (binary) to formatted string
    L NP_M4203_error_module_9xxx
    IFT
    L NP_W1022_module_error_status
    ENDI
