Newbie with Boss 1 or 2 retro questions - what can I salvage? [pics]
Picked up a series 1 CNC serial 99X so I guessing a 2 or 3. Was retrofitted perhaps in the mid 90's with an AH-HA system, power drawbar, elaborate filter and cooling system for the coolant. From searching the forum here I have a starting point in mind which is to salvage what I can and use the original steppers (unless that it is not wise). I am not sure there was a power supply for the drivers unless it is contained within the ah ha. Not sure what this 240 VAC box is for but it is 60 + lbs. Had to pull the head to get it into the garage. Thanks in advance for any advice on this
