eztrak will not home, axis fault, axis not on, but when powering up the mill, the axis kind of lock with heavy resistance to turn by hand. Who can check the BMDC card to see what if anything needs replaced? Thank you much for any info, Doug
Could be your AxisBob card and or limit switches. You can check limits in diagnostics to see if they're changing. I had an EZ trak that showed the limit for X stuck on but it wasn't. (Home Switch)
Ended up being the AxisBob card. We replaced it along with a software upgrade and a USB drive. Running again.
