Torq Cut Backup, Dos 6.2 or DOS 6.22??
Results 1 to 12 of 12
Thread: Torq Cut Backup, Dos 6.2 or DOS 6.22??
    Dec 2009
    Default Torq Cut Backup, Dos 6.2 or DOS 6.22??
    OK, I have a Torque Cut 22 with the transmission.
    I did not get the original Bridgeport Software disk.
    I ran MAKEDISK. BAT from the command prompt. It created the backup disk BUT these files were not found:
    PFM.EXE
    WM.EXE
    ACADMGR.BAT
    MACROS.EMB
    LEADCOMP.DAT
    Machine is running Dos 6.2, Do I read correctly that you HAVE to run 6.2 and can't run 6.22? (I have 6.22, but not 6.2 and it appears not all of the DOS files are in the C:\DOS directory. I suspect the hard drive was replaced in the past but perhaps not all the files were restored to the drive.
    Firstly, anyone with a Torq Cut 22 and the transmission run MAKEDISK and found they were missing these files?
    What does the original Bridgeport Software disk cost? (I have the latest version I believe, BPC-MC=V4.79.22/6.89.57
    Help with this appreciated. I wanted to also replace the hard drive with a DOM 256mb (Disk on Module) industrial IDE drive. I have done this before with another machine. And then just leave the hard disk in the machine disconnected as a back up besides the floppy.
    Marty
    Dec 2009
    Default Re: Torq Cut Backup, Dos 6.2 or DOS 6.22??
    I was able to install the DOM ok. The process appears to be that you must first install DOS on the drive, then run INSTALL from the floppy created with MAKEDISK.
    I would like to know about the missing files and whether or not there is a compatibility issue with Dos 6.22 and the Bridgeport software
    Marty
    Aug 2014
    Havent made any backups personally but mine has a transmission and came with disks pictured which are supposed to be all the latest firmware. If you want I can try to backup and upload anything you might need.
    Attached Thumbnails Attached Thumbnails Torq Cut Backup, Dos 6.2 or DOS 6.22??-20161218_084024-jpg
    Aug 2014
    For anyone else interested here is a backup of my 1996 Torq Cut 22 with 7,500 RPM transmission: https://www.dropbox.com/s/93zjqpac7dkehgo/FLOPPY003.zip
    Seems to be missing files BXT_GHLP.MSG and ACADMGR.BAT but otherwise has been working well for me so far.
    Dec 2009
    Quote Originally Posted by hax0red View Post
    Thanks for sharing this with us Chris. What a great bunch of people, helping each other out!
    Dec 2009
    You are running Dos 6.22 just fine on your machine?
    Marty
  7. #7
    Dec 2009
    Quote Originally Posted by Marty_Escarcega View Post
    PFM.EXE
    WM.EXE
    ACADMGR.BAT
    MACROS.EMB
    LEADCOMP.DAT
    Marty
    I have a question, what is contained in the MACROS.EMB file? Does this have the homing sequence for the tool changer?
  8. #8
    Aug 2014
    Marty
    Sorry, I had a pretty long day yesterday but finally confirmed my machine is running 6.22 without issue.
    Not sure about the macros file but in Mach 3 macros written in vbscript are used to control the tool changer either directly or indirectly via a PLC/something similar....not sure which is the case here though. Is your tooo changer running ok? I believe most of the adjustment is mechanical but the Z change height and dog drive position is setup through the tool changer menu. Retract height on mine is set to a fixed 4".
    Attached Thumbnails Attached Thumbnails Torq Cut Backup, Dos 6.2 or DOS 6.22??-20161220_005017-jpg
  9. #9
    Dec 2005
    Marty, I would recommend making an image of the DOM to another drive using Acronis True Image, Clonezilla, or similar imaging software. My image is less than 5 megs. I simply pulled the DOM and put it in an old PC and made an image. I've even used the image a few times restored to an old pc when I wanted to hack around the system without risking the integrity of my machine, once I was happy with my changes I applied them to my machine.
    I wouldn't trust a floppy long term.
  10. #10
    Dec 2009
    Great! Thanks for confirming this
    Marty
  11. #11
    Dec 2009
    I was hoping MACTEC would chime in. What is the MACROS.EMB file?
    Marty
  12. #12
    Dec 2009
    Marty
    Agreed.
    My first step was to pull the data off the hard disk. MAKEDISK did that. I formatted the DOM, installed DOS, then ran INSTALL. Worked fine. My issue is that I did not have a MACROS.EMB file and I think Mactec said it was needed for homing the ATC. Asking for confirmation on that.
    I'm still working on the machine (its running, just maintenance items). Hopefully I will learn to set it up and get it cutting parts soon.
