Originally Posted by
mactec54
You have need a 60A single phase supply the wiring that is in the machine is more than enough to support this, the VFD Drive is over rated for this machine, and is a very robust Drive, these where a special built VFD Drive to suit the spindle motors, they are not just a regular General purpose VFD Drive, they are closer to a Servo Drive and program the same way as a Servo Drive, like everything they have a life cycle, and will fail over time, no matter how they are used
Your spindle drive will fault out if there was a problem, before you will have any fuse or wiring problem, your spindle drive is as much as you want to pay for one, I would love to be able to get 6 or 7 thousand for one of these spindle drives, I have about fifty of them new in the box, I had so many of them I was selling them at a very low price at one time
Cap's in the Drives Yaskawa recommends there replacement every 2 years, but nobody does, when they do go most of the time they damage the boards making them not repairable if too badly damaged
