BTW I have 240v across the two hots. Is this too high?
Mactec54
Its wired just like VFD. I think i made sure or did everytbing you suggested.
Sent from my LG-LS997 using Tapatalk
Its wired just like Hax i ment not VFD.
Ok I will try
I only have L1 and L2 hot (im sure you know this) So you saying hook L3 wire back to T (as if it was 3 Phase) and jumper from R to T on the VFD?
Mactec54
Thanks. I did so but error remains.
Anyone know how to make sure that the problem is the VFD and not some other component? All the Screen says is "Axis Drive Fault"
Like in the Diagnostic screen? I would hate to ship this to be repaired and the VFD not be the problem is all.
And why in the Hell cant not find what the error F-600 is anywhere in my VFD manual. If the problem is the 240v+ across my hots, how can I bring that down?
TIA
I though you had fixed the VFD and was ready to run it again I posted what F-600 was, don't keep trying it, unless you have fixed it
Did you check FU1 and FU2 fuses also FU3 and FU4 these are on the Power Interface Card
For your Voltage you may find a Buck Booster Transformer or a regular Transformer should do the trick 220v Range should be a safer place to be
Does your machine home ok
Mactec54
Mactec54
Is there anyone still on here about this thread? I've got a TC22 that I bought from local tech school, and have had trouble with . Bought a 30hp American Rotary phase converter, 30 kva transformer that Iv'e tapped 240 delta to 208 wye because I didnt like the "wild leg", before I ever applied power. And now am getting a fault telling me that the BDCM is the wrong software. I would really appriciate any help. Thanks.
I run 240v delta, I see no issues running 240v delta. Understand the wild leg is only in reference to ground, not between phases.
Generally when you change voltages on equipment you also need to change the control transformer. I'd start by either attempting on 240v or change your control transformer to 208v. It's possible the PC power supply is running low, causing the BCDM to not post correctly.
I'd also suggest re-seating the BCDM. It seems I've had to re-seat stuff every time I move a machine.
Thanks. I'll try the computer ps. I've already swapped motherboards, but still get the error. Only now did I find that I could have powered it from 240. Would've saved me around 3 grand if I'd of ran across this post in the beginning.Only gave 32 hundred for the machine. Hopefully the pc power supply is on the way out. I acquired a couple of spare NOS motherboards for in the future,didn't think about the ps being as old as the rest of the computer
Did you changed the control transformer step down from 208v to 120v instead of 240v to 120v? It may not make a huge issue as most PC power supplies are fairly tolerant but if the voltage is low who knows.
Having a good RPC opens a lot of options for more equipment.
Exit to DOS and run B3T.EXE to test the BCDM board.
