Hi!!
Anyone in this forum with Bridgeport milling machine have this measurement from y axis bearing assembly bracket ... attached photo with "???????"
Thank you in advance
Anyone here running a BR2J head at 4000 rpm?
I've wound my inverter up to 133Hz which gives 4000 rpm but didn't want to risk damage.
Seems the spec sheets show 2300 or 4200 rpm - is there a difference in models here?
Bending bits of metal in Hertfordshire - https://ddmetalproducts.co.uk
Hi!!
The larger dimension is approximately 40.6mm and the smaller 37.4mm
These were taken from my motor mount plate cad file but i may have filed them to fit later on so i cant be 100% certain the are correct
Its probably the best way
It should work, lots of ways to do this.
Watch out for backlash in the quill rack/pinion, might not be an issue but good to remember.
My conversion cutting steel plate shows the Z axis in action
I can not see the video I have posted above and others have gone the same way on my thread? Can anyone see it? What has gone wrong?
Cheers John
