TC22 ( Torq Cut 22 ) Probe. ( Wildhorse Inivations ) - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 65 of 65
Thread: TC22 ( Torq Cut 22 ) Probe. ( Wildhorse Inivations )
  1. #61
    Feb 2008
    Default Re: TC22 ( Torq Cut 22 ) Probe. ( Wildhorse Inivations )
    Hi, like others here, I have a Torq-Cut 22 with a DX-32 control and a Wildhorse probe. The probe works electromechanically - it will touch a surface and record a point. I cannot figure out how to enter a useful tip diameter, though, and if that information is in this thread, I missed it. When I call up a tool # and install the probe, say #24, and give that # a diameter in the tool table, the display shows "probe" and the diameter following it. However, I seem to be able to put any number in that field without affecting the location of a probed point. I also tried entering a diameter in the appropriate field in a Geometry calculation and then going back to probing from the jog menu - again, no effect on the measured point... Any ideas?
    TIA!
    Mark
  2. #62
    Feb 2008
    Hi, forhire - I tried to reply to you and got the following:
    "forhire has exceeded their stored private messages quota and cannot accept further messages until they clear some space."
    Thanks,
    Mark
  3. #63
    Dec 2005
    Quote Originally Posted by Mark McDade View Post
    Hi, forhire - I tried to reply to you and got the following: "forhire has exceeded their stored private messages quota and cannot accept further messages until they clear some space."
    CNCZone has a very small inbox allocation. I sent you a PM with the URL for the software and manual.
  4. #64
    Feb 2005
    The DX32 control has some parameters for the probe behavior. "Post Hit Continuation" and "Back Off Distance" which you might need to tune for your probe. I haven't fooled with these yet since I haven't bought a probe yet
  5. #65
    Feb 2008
    Quote Originally Posted by arsenix View Post
    There are three, 014, 015 and 016. I have played around with 15 and 16 and they don't seem to do anything (14 is probing speed and I didn't change it). I'm still puzzled that there doesn't seem to be a parameter or input field that allows compensation for probe diameter...
