- Need Help!- Bridgeport 412 with no power at the Heidenhain control
I am going to try and replace the power supply #2 ( in the side cabinet ) today and see if that's my problem.
Any suggestions would be great !
Thank You !!
Re: Bridgeport 412 with no power at the Heidenhain control
which control?
when the caps start going the fuse in the back of the earlier controls will blow
Hi ,
I Just replaced PS2 and when i turned the power on it started smoking. UGHHHHH !!!
- You may not post replies
- You may not edit your posts
Forum Rules
