- Milling Pockets for Steamchest.
After one more go at it I disvovered that I tried to mill a 2mm oblong slot with a 3mm endmill.
BobCam did not protest but just did not compute a path.
It works now like I wanted it.
Sorry for the post,
Jos
Hi all
I need help making pockets in a SW designed steam-chest.
I have tried for a couple of days to do this in BobCam V5.
Whatever I select, even adaptive pocketing, no tool-path is generated.
Will someone have a go at the attached file, please.
thanks,
Jos
the Netherlands
Reason: problem solved
- You may not post replies
- You may not edit your posts
Forum Rules
