- Is there a V5 Coming
As the title suggests with V28 out is there a V5 on route?
Not sure if there is any new features I would need except tabbing in 2D milling of profiles but improvements to the lathe side would be helpful.
Re: Is there a V5 Coming
They stagger the releases, adding new features to each one. The dynamic machining was implemented in the soldiworks plugin first, then added to V27. The solidworks plugins come out around November.
- You may not post replies
- You may not edit your posts
Forum Rules
