- Bob Cam for Solid Works 2013 issue.
Hi
I just purchase the add on for SW and keep on getting this error when i start up the program. I already went into the program and made my CNC router the default machine and keep on getting this error.
Re: Bob Cam for Solid Works 2013 issue.
Hi
You may have selected the machine but have you defined the machine?
Ghost
The files will keep what's called "Part" information... Think of it like Global defaults and also "per document" defaults... So if I send you a file I made, it will carry the information of "my machine, post processor" etc......
You would open that file, then select "Your machine" setup, then SAVE THE FILE, as yours.. Then it wont tell you that....
- You may not post replies
- You may not edit your posts
Forum Rules
