4 axis conical cut
Results 1 to 3 of 3
Thread: 4 axis conical cut
    May 2012
    Default 4 axis conical cut
    I am trying to cut a conical shape in wood using troyke 4 axis on a fadal machine programmed with mastercam. i want to use a flat endmill but instead of using the tip of the tool to cut i want to use the side as this generally leaves a nicer finish for sanding. anybody know how i can do this? i have tried changing settings in my toolpath but have so far been unsuccessful.
    thanks!
    Feb 2009
    Default Re: 4 axis conical cut
    Are you asking for Mastercam help in the BobCAM forum? That's likely not going to yield too many useful replies...
    CAD, CAM, Scanning, Modelling, Machining...
    May 2012
    ha ha thanks i'll put the question in the correct place
4 axis conical cut
4 axis conical cut
